by Willmorgs58 Investigator
Gutted my EE hawk hasn't got a screenshot facility.Spoils the phone.
Gutted my EE hawk smartphone hasn't got a screenshot option on it,spoils what is otherwise a decent phone.
6 REPLIES 6
Re: Gutted my EE hawk hasn't got a screenshot facility.Spoils the phone.
Hello..yes there is a screenshot facility it's bottom volume and power
button together.thanks for replying anyway
by Star Contributor
Star Contributor
The Hawk does have a screenshot facility. Press and hold power and volume down together at the same time.
by Skilled Contributor
Skilled Contributor
Even if they have for some reason disabled the built in Android shortcut for screenshots, have you looked on the Google Play Store for an app to do the same?
I'd be shocked if there wasn't.
Oh great,thanks for your help😊
Hi @Willmorgs58
I'm happy to see that you managed to find out how to do this.  🙂
Feel free to come back to the community any time.
Chris 🙂
Skilled Contributor
Indeed - I use Screen Capture Shortcut because it lets you run the app then minimise it to just a "capture" button in the corner. But you're right, there's quite a few if the OP looks, bound to find one that suits.
