05-04-2020 07:56 PM
How do I enable this? I have tried to merge calls but it won't work on my S10+. Please help.
06-04-2020 02:39 PM
Hi @Dahir.
Welcome to the community.
Have a look at our EE Group Call help page to see how to use group call.
Hope this helps.
Jon
26-09-2020 09:30 PM
How do I set up group call
27-09-2020 08:08 AM
Hi @Yumna.
Have a look at our Group Call Help Page for more information on this.
You make up your own pin and give it to other attendees.
Jon
03-03-2021 04:24 PM
Hello,
Group Call Help Page isn't active, could someone confirm how do a group call as EE removed the merge calls feature?
TIA
03-03-2021 04:31 PM
Hi @smithy23
There are a whole host of apps you can use for group calls. Please search your app store for more information.
03-03-2021 04:41 PM
04-05-2021 07:27 AM
Yes EE have for some strange reason removed The merge calls feature and now closed the Confrence call feature. It’s the most annoying decision they have made. All phones are now able to merge calls but EE the biggest network are the only network to have stopped you using the feature
04-05-2021 07:31 AM
@Russ14 Just because a device can support a feature it doesn’t mean the network has to also.
04-05-2021 07:47 AM
@Chris_B I never said it did but it’s annoying that they used to allow the feature. I also know customers that can still use the feature!
when they stopped the feature they created the group call number instead which they’ve now removed which no option of a replacement. Instead tell you to use platforms that use data and nail your phone battery
