by markrach78 Investigator
Google Pixel Microphone Problems
Seems my Pixel is having problems my Mic stops working all of a sudden then mysteriously starts working again the phone is just over 2 weeks old and i cant seem to find out what to do , my EE shop told me to call Google as they informed me it was a known problem, then Google told me to contact my carrier (EE) as they have to deal with it!!
Who is correct here i have a semi working £500 phone on a 24month agreement someone needs to take charge
EE Employee
Solution
Re: Google Pixel Microphone Problems
Good Morning @markrach78
As it's within 28 days the store will be able to replace the device for you.
I've confirmed this would be the case even if it was a known issue.
You may have already done this but if not you'll need to back up the device, do a factory reset and test the device.
It's more than likely not a software fault but it just rules it out.
Pop back and let us know how it goes!
Thanks - Karen. Smiley Happy
14 REPLIES 14
by Brilliant Contributor
Either can sort this out.
EE can take it in for repair or so can google.
by Star Contributor
Star Contributor
Hi
I believe Google has said to send the back to them if it was bought direct as it is a known hardware issue.
http://www.theverge.com/2017/3/9/14868400/google-pixel-microphone-issues
https://support.google.com/pixelphone/forum/AAAAb4-OgUsIW_gxTpXX3s/?hl=by
As this is bought via EE i suspect they will honor the acknowledgement its a known issue and replace it.
Mark
Hi
It was purchased via EE (Local Store) so they could replace it for me yes?, i dont want to change the phone as i love it its great just this issue it has.
EE will not replace it but most likely send it back to Google.
Google will then either repair or replace.
EE Employee
Good Afternoon @markrach78
When exactly did you get the device - are you within 28 days?
What store was it from?
Hi
Yes the handset was purchased on 26/2/2017
EE Store in Argos Bletchley (Handset was purchased from a store 3 miles away from this one) Milton Keynes
Was told this Sunday just gone
EE Employee
Hi @markrach78
I am awaiting some information back from my retail team in regards to this.
Either myself or @Karen_C will be in touch soon as we have more details.
Many thanks,
Lee
Thank you.
Hope to hear from you soon.
Good morning,
Do we have any update on this please.
Rachel
EE Employee
Solution
by whalleys5
hi my mic has stopped working i can no longer make or receive calls, i have had the phone 12 months, i cant phone ee because of this, could you please advise.
stephen.
Hello there @whalleys5
Thanks for posting on the community.
If you use our online troubleshooter tool  for your problem this will let you know what is needed.
You can book a repair through the tool if this is required.
Hope you get this sorted 🙂
by whalleys5
thats brilliant , thank you Smiley Very Happy
No problem at all @whalleys5
Have a great day 🙂
