by Jeffthemackem
New Member
Going to Mexico at Christmas. Can I use my 4g allowance
Going to Mexico this Xmas. Can I use my 4g allowance?
Solution
Re: Going to Mexico at Christmas. Can I use my 4g allowance
Hi @Jeffthemackem
Yes you can, but depending on the tariff you have you may have free roaming. If you have one of the new swappable tariffs with The roam further swappable, or an EE max plan taken out after 10/05/17 then you can roam as at home (15GB maximum data fair use limit)
Alternatively roaming costs for Mexico cam be found here;
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/mexico
Just remember to text ROAMING to 150 to ensure your service is activated.
Solution
Hi @Jeffthemackem
