by Skilled Contributor
Skilled Contributor
Galaxy S9 - Updates (again) yawn!
EE care to comment why the S9 is 4 updates behind on EE EVR?  Still on ARD1 on EVR yet ARD4, BRE5, BRF3 & BRF8 have been released by Samsung with some very important patches???
"your handset will notify you as and when an update becomes available".  "we thoroughly test all updates blah blah" <-  See I did it for you.
I know i'm banging on again but now can we have a serious reply to WHY it's taking 3 months and 4 missed updates on a flagship handset? Seriously?
Build Number : G960FXXU1BRF8
Android version : Oreo(Android 8.0.0)
Release Date : 2018-06-26
Security patch level : 2018-06-01
· A new Hey google function has been added
· The stability of Device has been improved.
· The security of your device has been improved.
· GDPR has been added.(General Data Protection Regulation)
Build Number : G960FXXS1BRF3
Release Date : 2018-06-21
Build Number : G960FXXU1BRE5
Release Date : 2018-05-24
· Improved performance. - VoLTE, VoWIFI
· Dual VoLTE/VoWIFI service is available for both of the SIM cards in the dual SIM slots.
  ( ※ The service is provided only to dual SIM devices and can still be limited depending on the service operator for each SIM card. )
Build Number : G960FXXU1ARD4
Release Date : 2018-05-11
· Call stability has been improved.
· The quality of Wallpaper has been improved.
10 REPLIES 10
by Brilliant Contributor
Re: Galaxy S9 - Updates (again) yawn!
@terracuk well said waiting for same on s9 plus.
I really don’t see the hold up as justified other networks don’t need this long to “test”
Hi @terracuk
I don't know if you've had a look yet, but, we have a software update blog post that explains how software updates are processed.
Once an update has been given the OK by everyone involved, approval to launch and deploy is given. The update is then added to the supplier's servers for rolling out over-the-air.
by fridgeman Investigator
You can now use Volte on BTU firmware
Skilled Contributor
@Christopher_G wrote:
Hi @terracuk
So we are led to believe that 4 updates from Samsung are not good enough for EE to release?  EE have knocked these back and waiting for Samsung to release something that is adequate?
@fridgeman are you sure? On what software version? Do you know if that works on s9 plus too?
Bought my S9+ duos from Samsung, updated to the latest over the air firmware and I now have Volte.Screenshot_20180706-180132_Software update.jpg
Great thanks for that @fridgeman Just flashed mine back to btu and indeed it does work 👍
However one thing do you know why it enables location when you connect to WiFi I think it’s to do with WiFi calling as when I come back in it switches it on.
Really don’t want my battery run down because I keep forgetting to turn it off
Settings,wifi,advanced turn on wifi automatically??
Thanks but that needs location too. I can’t see why you would need location for WiFi or WiFi calling. It didn’t on the Ee firmware.
Skilled Contributor
New update out today for EVR (G960FXXU1BRF8)
