by MatthewS Investigator
Galaxy S7 update home screen spacing
Hi
I received update G930FXXU1DQJ3/G930FEVR1DQJ1/G930FXXU1DQIL a few hours ago for my Galaxy S7.
Since updating, the home screen now has a large empty space at the top of the screen between the notification & status bar and my apps/widgets.
It's a pretty big piece of screen real estate to lose and just looks wrong being empty (apart from the wallpaper).  Is anyone experiencing the same or has a fix?  Thanks
21 REPLIES 21
Re: Galaxy S7 update home screen spacing
Have you tried factory resetting your phone. You should do this after any major update.
Also you could try setting your wallpaper again.
EE Employee
Hi @MatthewS and welcome to the community.
Please do let us know how you get on after following the advice given by @Northerner.
Many thanks,
Lee
Hi @MatthewS,
What occupied that part of the screen before you upgraded?
I've had to add widgets such as the clock back onto the home screen after major updates in the past.
Thanks all
@James_BPreviously, the apps and widgets filled the space.  It's like there's now padding at the top that's pushed the apps and widgets down.  So there's just a large void between the notification & status bar and where my apps/widgets begin.
Have tried:
Changing the wallpaper
Changing the theme
Changing screen resolution
Changing Screen zoom and font
Wiped system cache
Bunch of other things I've forgotten
I'll try the factory reset later when near power.  Thanks again
Hi @MatthewS,
Just to double check before you factory reset, are you able to drag apps into the space?
Hi @James_B
No, I'm not able to drag apps or widgets into the space.  I can hover apps over it, but they drop/snap into the nearest empty container below.
OK @MatthewS, worth a try!
Let us know if the factory reset helps.
Hi
Unfortunately a factory reset hasn't fixed it.
EE Employee
Hi @MatthewS
Have you noticed any talk on the Samsung forums or XDA developers in regards to this?
Many thanks,
Lee
Hi @Lee_H
Yes, I found the following thread on the XDA developers forum
https://forum.xda-developers.com/s7-edge/help/free-space-home-screen-update-t3650504
It describes the same issue I'm having, but it's on other phones and carriers.  Sadly no fix suggestions other than to roll back the firmware version.  I haven't found discussion of this problem anywhere else.
EE Employee
Hi @MatthewS
I wonder if @BrendonH or @Northerner has noticed anything on their devices?
Many thanks,
Lee
by Brilliant Contributor
@MatthewS
Dial *#1234# and share the info please. Want to see if there is a pattern here and if it is happening from certain firmware from same region/network.
EE Employee
I knew you would be on this @BrendonH 🙂
Cheers
Lee
Hi @BrendonH
AP : G930FXXU1DQJ3
CP : G930FXXU1DQIL
CSC : G930FEVR1DQJ1
Model : SM-G930F
Hi @MatthewS
Now I have seen the pictures I have now noticed the same on my S8+
I can only assume it's a launcher/grid layout oddity.
@Northerner wrote:
Hi @MatthewS
You are right there is a gap on top of my S8+ But I never noticed if it has changed or not.
@MatthewS so you have EE firmware others seem to have XEO so not really a pattern.
I have BTU (Oreo Beta)
I guess the only solution is what was mentioned in the XDA forum.
Wait for a patch or revert back a firmware.
@MatthewS
Thanks for pointing it out as I will notice it every time I look my phone!!!!! 😂
Thanks for looking everyone.  Sorry you guys have the oddity too, although with all that extra screen on the S8+, I'm not too sorry 😉
I'll wait for a patch/update.
Cheers all
EE Employee
Haha @MatthewS
I'm glad its not like that on my Huawei P10 😉
Cheers
Lee
