by Yellowmatic Established Contributor
Galaxy S6 fast charging not working anymore.
For the past couple of weeks fast charging doesn't seem to work anymore, if anything it's slower than it would be on a normal charger. Painfully slow, in fact.  But it still says "fast charging" on the screen. I tried plugging it in my other Samsung charger (for the tablet) and it seems to charge ok, albeit at normal speed. Also, it would make a sound when plugged in, then another immediately after confirming fast charging, now it only makes the sound once and as I said, it does say fast charging, but it most definitely isn't!
Solution
Re: Galaxy S6 fast charging not working anymore.
Thanks @Yellowmatic.
In this case if you get in touch with our customer service team they can see what can be done to help you with this.
Let me know how you get on 🙂
Your battery maybe on its way out.
It maybe worth contacting Samsung mobile support to see if the phone is still under warranty.
Good Afternoon @Yellowmatic
Welcome back to the community.
How long have you had the device for?
Is this on an EE personal contract?
Thanks 🙂
Yes Leanne, personal 24 month contract. Bought the phone on 3/1/2016.
Cheers.
Solution
by Ace Contributor
I'd recommend a factory reset. Backup your data first, it will wipe everything.
