by Marbyk Investigator
Galaxy S10+ battery drain
Hi, I am experiencing battery issue on my S10 plus. Battery drains from 100% to 70% within 3 hours even tho I'm not using my phone. My old s8plus stayed on 60% after 8hrs and bigger usage of the phone. I have completely same settings. Anyone knows how to fix it?
8 REPLIES 8
Re: Galaxy S10+ battery drain
@Marbyk  it’s perfectly normal as the device/battery is in setting up stage.   How long have you had it ?
Since release. At first I thought it's in setting stage but it's been 11 days already and I did switch off GPS, WiFi, and screen wake up when you lift the phone but nothing worked. I did read a lot of great comments about its battery and I think 11 days was enough to set it up
by Brilliant Contributor
Is it in your pocket by any chance with the screen facing your leg?
It may be trying to unlock the device with the fingerprint reader by touching your leg.
This is an issue with this device which Samsung say will fix in a future update.
I do. I might try tomorrow facing it the other way and see
I can confirm that it was issue when the phone tried to unlock while it was facing my leg. Normally I carry 2 phones so I did keep my company phone in front of 10plus and battery last longer but unfortunately not as good as my old s8plus 😕
by Tariqca15
Hi I had the same issue on my s10 plus battery would drain by 30 percent within 3 hours so what I did was I am also on 02 i tested the phone out one day on 02 and battery was on 80 percent from 5am to 3pm then the following day i re did the test with ee sim battery from.5 am was at 39 percent by 3pm doing exactly the same on the phone over the 2 days period
@Tariqca15   Did you read what was the cause for @Marbyk  as it appears you didn’t.  Nothing todo with the network the device was on.
by Tariqca15
Yes but I have a s10 plus battery was draining even though the display was off
And its obvious it's the network eating battery over LTE
