by martinfid
Galaxy S 7 Edge won't switch on or charge after update last night
My phone had an update last night but today it wouldn't switch on, tried charging it up but it doesn't look like it is charging, I've tried all the resetting suggestions using the home key and the power button or volume buttons but nothing works at all, any Idea what I can try or were I can go to get it fixed?
by Brilliant Contributor
Re: Galaxy S 7 Edge won't switch on or charge after update last night
Hold Volume up home Bupton and power buttons together for about 10 seconds.
by martinfid
tried resetting using the power and home keys, no sign of life...
Did the update seem to go through alright?
Seems like it may have bricked.
Good morning @martinfid
Welcome to community 🙂
I know you've already been given some help by @BrendonH
Just checking in to see if you have managed to fix the problem you were having?
Richard
