by Ch04oco
Fast charger not fast charging
  • Can i get proof of purchase so that I can get a replacement charger from Samsung?
Solution
Re: Fast charger not fast charging
If you contact EE CS on 150 they can provide this
Solution
by Brilliant Contributor
Are you sure you have fast charging enabled on your phone?
Settings > Battery
Then go straight to the bottom.
