Highlighted
Factory reset lost my phone contacts
Hello all . I've got a Samsung galaxy s5 and I done factory reset and I've lost all my contacts.  Is there a way to get them back ... thanks again
Highlighted
Re: Factory reset lost my phone contacts
Hi @Eeyore79
If you have backed them up on Google via your Google phone account you will be asked if you want to download them when you go through the initial registration process.
Also check you haven't backed them up on your Samsung account (if you registered one).
Highlighted
Morning @Eeyore79
Has the advice from @Northerner helped you get your contacts back?
Hope to hear back from you soon.
Leanne 🙂
