by DazT Investigator
Excessive battery drain overnight oneplus 7pro
Hi, since I've had my oneplus 7 pro the battery overnight is draining by 30% while I sleep. Surely this can't be normal? Battery usage doesn't show any one app using battery overnight so I'm a bit stumped?
Anyone got any ideas or should I return the phone.
Solution
Re: Excessive battery drain overnight oneplus 7pro
@DazT   Try a factory restart first.  If the issue is still there then take it to a store so it can be looked at.
if you got the device from a store you get 12 days to take it back if there is a fault with the device to get it exchanged after that your device get sent off for repair
7 REPLIES 7
Solution
I've had it longer than twelve days but I will try the factory reset.
Hi @DazT
Welcome to the community.
It does seem strange that the usage doesn't show on your battery usage.
Let us know if it's any better after the factory reset.
Turned off 5g, overnight, see if it was that searching for a network I don't have. No such luck. Screenshot_20190917-070236.jpg
Hi @DazT
Thanks for coming back to us.
In this case, if you can get in touch with our Tech Gurus on 150, they will be able to help you further 🙂
Let us know how it goes.
Factory reset, with all my apps restored seems to have solved things. 4% battery usage overnight which is what I would expect. I'm sure I had a os update at some point on this phone so maybe it was that as I've not had one yet.
Anyway thanks for the help Chris B
Thanks for the update @DazT 🙂
