by FlapZappa Investigator
Ee network Battery drain
I mainly use my phone abroad and it will happily have 60% or more charge left at the end of the day, I have been in the UK for a week and using an ee sim, since then my phone barely lasts 12 hours before it is down to 15%. The only difference in usage is I am on ee. Wifi is off, Bluetooth is off, data connection off except when I need access.
It is definitely something to do with the ee network
Battery drain
by Ace Contributor
Re: Battery drain
Hi.
@FlapZappa
If you can backup your phone data please backup and do a factory rest.
And also keep off GPS (location services) unless if you need them.
here is some tips you can have a look on them as well Troubleshoot a battery that drains too fast
I hope it will help you to sort your issue out,
Many Thanks
Re: Ee network Battery drain
Hi @FlapZappa,
Welcome to the EE Community.
Are you in a low signal area?
