Highlighted
Ee locked phone with bt sim
Can someone tell me with 100% certainty if a Galaxy s9 locked to ee will work with a BT pay monthly SIM?
Highlighted
Solution
Re: Ee locked phone with bt sim
Hi @returnofjim,
Welcome to the EE Community.
Your EE phone would need to be unlocked to use a BT SIM.
Highlighted
Solution
Hi @returnofjim,
Highlighted
by Ace Contributor
@returnofjim To make it easier for the future, is it worth just getting it unlocked from EE?
Unlocking Link
