by stuarttunstall Established Contributor
Edgelight missing from Bixby
Hi
 Is it just me or as anyone else noticed that since an update of the Bixby app the edge light has stopped working, and Bixby is not shown in the Edgelight settings....
 When Bixby used to "bleep" to say it had a notification the left hand edge used to flash prompting you to swipe the screen to see Bixby... mine no longer does this on my S8+ 😞
 Anyone else noticed this?
Stuart
6 REPLIES 6
Re: Edgelight missing from Bixby
Hi @stuarttunstall
Thanks for posting here again 🙂
I'm going to tag in @BrendonH to see if he can possible offer some help.
Cheers
Richard
No problem, as I say it seems to have disappeared since the last, maybe the one before update of Bixby...
I have checked the apps list for edglight and Bixby is not in there...
Let's see what @BrendonH says when he's around.
Richard
by Brilliant Contributor
I'm sorry. But I can't help here.
I noticed it has stopped to and can only think it's something Samsung has decided to change.
I have checked every setting possible.
Thank you.... I was beginning to think it was me lol ...
I think it happened either with the last update or the one before
Stu
EE Employee
Hi @stuarttunstall
Have you spoken to Samsung at all in regards to this?
Many thanks,
Lee
