Highlighted
New Member
EMUI 10 - Mobile Data Problems
Just updated to EMUI 10 on my P30 Pro, however my mobile data seems to be goosed.  Set up a new APN using the data provided by EE for internet access, still no joy.  I can't delete or amend the built-in APN but is definitely using the one I set up.  I'd rather not roll back to 9.1 , does anyone have a solution for this?
UPDATE - set it to IPv4 only, I had it set to IPv4/IPv6. Seems to be working so far.
Highlighted
Re: EMUI 10 - Mobile Data Problems
Welcome to the community, @rdunn3165
Thanks for coming back to us with your update. 🙂
Highlighted
by Investigator
Can someone please tell me when I'm going to receive the update, its been out for what a week on ee and still nothing! I have a p30 pro from Carphone Warehouse so should be unlocked. Getting a little silly now!
Highlighted
Hi @Neils67
Welcome to the community.
We always aim to deliver software updates to customers in as efficient a manner as possible. We work tirelessly to make sure that any updates do not have a negative impact on how your phone behaves on a day-to-day basis, so we test them thoroughly.
If anything is found, the manufacturer usually needs a week or two to fix these and then send back to us to re-test.
We have no reason to unnecessarily withhold or delay any software or security updates.
Thanks for your patience.
Highlighted
by Investigator
Hi Chris, thanks for your reply, unfortunately it doesn't really answer my question. If I go to EE tech support they don't seem to know anything, if you go to Huawei they don't respond, so how is the customer meant to get answers, if not through the Community pages? Just saying be patient isn't really an answer, it feels like just a corporate response. If it was a few days or a week fine, but the update has been out since December and all other networks have delivered it, really frustrating.
