by kmdm Investigator
EE wifi calling not working at home
I was hoping someone could point me in the right direction for how to solve this.
I have two devices:
 * Google Pixel (non-EE), personal mobile
 * Apple iPhone 5S, company mobile
In the office at work both devices will use EE WiFi Calling and I see the appropriate indicators next to the EE operator name on both.
At home, the iPhone will still indicate WiFiCall but the Google Pixel will not. I'm not really sure how to debug this further, since:
 * It works from the office so WiFi Calling is enabled on my account; and
 * The iPhone works at home so it wouldn't appear to be my router or local network config; and
 * There's nothing glaringly obvious in the 'adb logcat' output from home (with regards to case insensitive filters lke QCNEJ, WiFi and Wfc)
I'm happy to investigate further but I'm not really sure how to given it seems like it just doesn't try to initiate a WiFi calling "connection".
Any help appreciated.
Thanks,
Kenny
6 REPLIES 6
by Ace Contributor
Re: EE wifi calling not working at home
Hi @kmdm Have you tried just turning your phone off and on again, and also rebooting your router?
What happens if you place your Pixel into airplane mode and turn wifi back on, does it pick up EE Wifi calling?
I'm more surprised it works on your iPhone now Apple have changed the way it works so if you have a 4G signal it prefers that instead of wifi calling.
Yep - I've tried turning it off/on and rebooting the router.
It consistently 'connects' to WiFi Calling at work and consistently does not at home.
The iPhone shows "EE WiFiCall" at both the office and at home.
The Pixel only shows "EE Wi-Fi Calling" at the office.
I'm at a loss of what to check at this point since I can't really find out the connectivity involved in establishing a WiFi calling 'connection' or how its availability is determined.
EE Employee
Hi and welcome to the community @kmdm
Can I get you to try and pop your Pixel into safe mode whilst at home to see if that helps?
Many thanks,
Lee
Hi @kmdm
Two suggestions:
1. Try changing your wifi channel at home.
2. Ensure you are connected to the 2.4GHz or if you are change it to the 5GHz signal.
Thanks,
Thanks both.
I'll try the suggestions given:
* Safe mode; and
* Disabling 5Ghz (same SSID)
I appreciate the WiFi channel suggestion but I've already ensured it's not on any sort of overlap with surrounding wireless networks (E.g. the full 1, 6, 11 consideration.)
EE Employee
Let us know how you get on @kmdm
Many thanks,
Lee
