by richmondking452
New Member
EE Harrier Mini
Hi
I have recently obtained a harrier mini mobile phone on contract, the green light is flashing to show that it is on but the screen is in darkness and I am unable to remove the battery in order to reboot the system please can someone help me with this problem.
Thankyou for in advance for your time
Solution
Re: EE Harrier Mini
Hi @richmondking452
Thank you for coming to community 🙂
Please check out our EE HARRIER MINI - PERFORM A SOFT RESET help and support pages.
Perform a Soft Reset
Find out how to reboot the device manually if you are encountering issues with the OS or applications.
  1. With the device turned on, press and hold the Power button and Volume up button for at least 5 seconds or until the device starts to vibrate.
    NoteWhen the Power Off option appears on screen, ignore it and continue to hold the buttons.
  2. Release the Power button and the Volume up button.
  3. The device will turn off completely.
  4. The device will reboot automatically.
The soft reset is complete.
If you need any further support please GET IN TOUCH with our technical support team.
Best of luck
Richard
Solution
Re: EE Harrier Mini
Hi @richmondking452
Best of luck
Richard
