by FT1708 Investigator
EE Harrier Mini Lockscreen
Hi I Currently Have A EE Harrier Mini I Had It For A Few Months By Now. I Was Just Wondering If Anyone Knew How To Change The Lockscreen Wallpaper? Because When I Go On Settings Or Any Other Type Of Information It Doesn't Show An Option To Change The Wallpaper For Some Reason. If Anyone Does Have An EE Harrier Mini And Knows How To Change The Lockscreen For That Sort Of Device Please Let Me Know And I Would Be Gratefully Appreciate It For An Answer. Thank You. - FT1708 🙂
Re: EE Harrier Mini Lockscreen
If you choose the picture you want and then -  settings there should be the "set as wallpaper"  option click on this and it should ask if you want to set it as lock screen or wallpaper etc.
Okay Thank You Very Much I Will Try That 🙂
