by WelshBen Contributor
Does s cable connection sffect wireless signal
My wireless signal has gone really weak.
My TV is considered by cable.
Could this affect the wireless signal which now lacks bandwidth and contact distance within my flat?
by Ace Contributor
Solution
Re: Weak wireless signal
No your TV cable should have no interference with your Wi-Fi signal.
Is the space around your router clear? No photo frames or ornaments? Porcelain is one of the worst materials for blocking signal.
11 REPLIES 11
>From my router of course
by Ace Contributor
Re: Does s cable connection sffect wireless signal
Hello @WelshBen unless you made a change to your TV set up at the same time as your signal dropping it is unlikely to be the reason no.
Is this your phones signal or Wi-Fi signal?
Wireless signal from what? Is this from a Home Broadband router?
by Ace Contributor
Solution
All clear but thanks.
Tried another channel change, will maybe help
by Ace Contributor
You are welcome. I hope changing the channel works out for you.
We are here if you need anything else in the meantime.
Cheers
Hi @WelshBen,
Welcome back to the community.
In addition to the great tips you've already had, you may find this wireless performance help article useful.
Hope this helps, please let us know how you get on.
Thanks TM90.
Chabging channel had hekped, seems TalkTalk were signal hogging
by Ace Contributor
You are welcome. I am glad to hear your Wi-Fi signal has now returned to normal.
The community is here anytime if there is anything else you would like to discuss.
