by Margaretgarton Investigator
Do we get 0845 numbers free with EE
by Star Contributor
Star Contributor
Solution
Re: Do we get 0845 numbers free with EE
Hi @Margaretgarton
However, 0345 numbers are included in your allowance so if you can find an alternative number that starts with 0345, you will not be charged if you have an allowance.
Thanks,
Martyn
by Profile closed
Not applicable
Hello @Margaretgarton no 0845 numbers are chargablee on EE plans by default. You can purchase a recurring 084 & 087 add on however, that gives you 200 minutes to these numbers for £6 a month. Here is a link containing more information on the 084 & 087 add on and how to purchase it:
http://ee.co.uk/help/add-ons-benefits-and-plans/calling-texting-and-data-add-ons/084-and-087-numbers...
by Star Contributor
Star Contributor
Solution
Hi @Margaretgarton
Thanks,
Martyn
Thanks @martyn413 @Profile closed for the great advice.
Let us know if you need anything further @Margaretgarton.
Thanks Martyn your info was very helpful and very much appreciated
Glad you got the answer you needed 🙂
Have a great day @Margaretgarton.
