by Welshjen18 Investigator
Do not disturb
I've recently noticed my "Do not disturb" feature on my s8 doesn't work. I turn it on at nights. And still have notifications come through.
Anyone know how to fix this?
by Brilliant Contributor
Re: Do not disturb
Check the do not disturbed settings you may have it set to allow some notifications to come through.
Re: Do not disturb
Hi @Welshjen18
You may be able to adjust the notification settings under Settings > Notifications.
Re: Do not disturb
Thanks.
Will try it
