by lewisc_lfc
Do i have a warranty?
Hi i was wondering whether you could tell me if i have a warranty on my phone?
Solution
Re: Do i have a warranty?
Hi @lewisc_lfc,
Welcome to the EE Community. Smiley Happy
Please take a look at the device repair help page for more information.
If you bought your phone new it will come with at least a 1 year warranty from the manufacturer. Details will be found on docs. in the box.
by Skilled Contributor
Skilled Contributor
If you bought the phone directly from EE, you also have a warranty period of 1 year with them and can use their repair centre for any repairs.
You can also use the manufatcure warranty procedures if you wish, or if you bought your phone via CPW of whoever, you can contact them with any warranty issues too.
Edit: Remember, warranties do not cover accidental damage, so cracked screens, water damage etc will not be covered. Also, if you have a problem with your phone it may not be un-resolvable from your end. Do you have an issue with your phone? If so, what's the phone and the issue and I'm sure someone here can assist.
by lewisc_lfc
Yes, i purchased the phone through EE so will they have given me a warranty for atleast the year? Its a phone inside the phone the lights are flickering and when i turn the brightness up the screen goes white, sometimes the phone wont power up an its just a blank screen, how can i get in touch with someone over this? S7 edge samsung.
by Brilliant Contributor
Just pop into store or ring up EE.
To clarify. With Samsung products you get 2 years warranty.
Solution
Hi @lewisc_lfc,
