by Liz53
Do I need anti virus protection for my Hsuwei p20 pro
Solution
Re: Do I need anti virus protection for my Hsuwei p20 pro
Hi @Liz53
Basically no as you already have it.
Under apps you should have an app called "phone management" and that contains your anti virus software.
You should run this app monthly to spring clean your device.
Solution
Hi @Liz53
