by Amazinggrace Contributor
Different currency
Hi...does anyone know how to set my play store to uk currency pls as mine is showing AED(united arab emirates) i hv change my sim card and new phone but why is it i can't access to uk app.
Many thanks
by Ace Contributor
Solution
Re: Different currency
Hi
@Amazinggrace
You need to do that in Google play settings,
More details please click on this,
https://support.google.com/googleplay/answer/6220312?hl=en-GB
Many Thanks
by Ace Contributor
Solution
Hi
@Amazinggrace
Many Thanks
Great advice @tahirmian Smiley Happy
