by Scorpio91
Data usage
I have been trying to work out how much mobile data I'm using (so I don't get extra charges) but the settings on my phone say one thing and independent apps (I've tried 2, data tracker apps) say something completey different. Can somebody help?
Solution
Re: Data usage
@Scorpio91   Use the my EE app as this is going to report your data usage or you can use THIS as this is your EE account, 3rd party apps are only a guide and are not that accurate.
just to add you can not go over your data allowance if you do use all your data you’ll be redirected to a EE webpage to purchase a data add-on before you can use data again.
Solution
Re: Data usage
by Scorpio91
Re: Data usage
That's great thank you so much
