by Spuxor Investigator
Data usage settings
Hello I have just upgraded to Samsung galaxy s8+. When I go into settings, data usage it won't let me adjust my mobile data limit as it's set to 30gb and I get 40gb. But have no way in the settings to adjust this. Any help really appreciated
Re: Data usage settings
Also my girlfriend has  the same phone but on o2 and it has a settings button on that screen to adjust data usage
Hi @Spuxor
Welcome to the community. 🙂
Can it be found by following the instructions below:-
Tap Settings >>> Connections >>> Data Usage >>> Bill Cycle and usage alerts.
Let me know if that helps.
Hi Chris
Thank you for being so welcoming.
Yes that has solved the issue. Really appreciate you taking the time to respond.
Kind regards
Spuxor
Brilliant @Spuxor, thanks for letting me know.
Feel free to come back to the community if you have any questions in future. 🙂
