by Aecas75
Data not working
Hi u can use my data to get on any of my app it only work on WiFi what can I do to fix it
Re: Data not working
@Aecas75   Have you allowed these apps to use cellular data ?   Are you a contract or PAYG customer?  If you text BALANCE to 150 when does the return message say ? Just to check is cellular data enabled and is airplane mode switched off ?
