by Amykins380
Data gifting problem
Evening all.ive just gifted my daughter 10gb .I normally get a text straight away telling me I've gifted.that never happened .she hasn't got the data even tho it's showing on the account status.my account is showing it as gifted.it isn't showing in the day gifting history tho.any ideas or is it just the app running slow.ta mark
by Ace Contributor
Solution
Re: Data gifting problem
Hi, @Amykins380 you could check your data status http://add-on.ee.co.uk here.
You can also check this after restarting the phone that might help.
by Ace Contributor
Solution
Recent solutions
