by youngoz
Data allowance
My data allowance has updated today but instead of showing the 15gb allowance its showing 14.6gb. I have been connected to wifi for the last 12 hours so shouldn't have used any data. Why haven't i got the full allowance?
10 REPLIES 10
Re: Data allowance
@youngoz   Because at some point in the last 7h 20mins you’ve been connected to a cellular signal .  What device do you have ?
And click THIS it will show what you’ve used from your allowance and what’s left to be used.
by youngoz
Re: Data allowance
Thanks for the reply. I have a Samsung Galaxy S8.
by Brilliant Contributor
Re: Data allowance
On the Wi-Fi advanced settings.
Is the switch to mobile data on?
If yes is it on normal or aggressive mode?
Re: Data allowance
@BrendonH: There is no normal/aggressive mode on the S8?
Re: Data allowance
Yes there is!
Re: Data allowance
@BrendonH: You sure that's an S8? I don't see it.
Re: Data allowance
Think I know what phone I have @XRaySpeX
Re: Data allowance
So do I, @BrendonH!
by Expert Contributor
Expert Contributor
Re: Data allowance
It's definitely there on an S8. Connections>WiFi>Advanced
Re: Data allowance
Ah, it's under WiFi! Don't have that feature. It's grayed out. Ta!
