by stuarttunstall Established Contributor
Dashboard in Android Pie
Hi
 How do I access the dashboard which is supposed to be on Android pie? Do I need to download an app..
by Brilliant Contributor
Re: Dashboard in Android Pie
What phone you using.
The S10 has their own built into it's one UI called Digital Wellbeing.
You'll find it in the settings app.
Isn't that a Google Android app under Beta?
by Ace Contributor
It's the digital wellbeing app for Pixels...
https://play.google.com/store/apps/details?id=com.google.android.apps.wellbeing
HI
 I have a Samsung S8+ but it is not in the settings menu... I did a search and it did look like it was an additional app... so thank you for the link 🙂
 It does say it is not compatible with the s8+
Stuart
