by WelshBen Contributor
Create folders
My new galaxy s7 edge grouped apps into useful folders. After reboot these vanished & all apps are seperste.
How do I recreate the folders to hold like apps?
by Profile closed
Not applicable
Solution
Re: Create folders
Helllo @WelshBen tap and hold an app on the home screen until you are able to move it about then hold it over another app to create a folder. 🙂
by Profile closed
Not applicable
Solution
Re: Create folders
Re: Create folders
In addition to @Profile closed comments.
Once you have created one folder if you click on it you can change its name and add additional apps by tapping the cross symbol.
