by n1gel
Contacts
Why when I try and add contacts on my Huawei Smart phone does my name and email come up?
by Brilliant Contributor
Solution
Re: Contacts
That's just letting you know it's being stored on your Huawei account.
If you click on it you can change it for the contact to be stored elsewhere like the phone or sim.
If it's on the Huawei account it means it backs up so of you lose all your contacts you use that to restore.
Solution
Re: Contacts
by n1gel
Re: Contacts
Cheers
EE Employee
Re: Contacts
Hi @n1gel and welcome to the community.
Your details are backing up to the Huawei cloud storage, which is a great thing because you will never lose your contacts etc.
Many thanks,
Lee
