by Silviu8
New Member
Close contract
Hello! I want to close the contract because I don't need it anymore.
What should I do to close it?
by Ace Contributor
Solution
Re: Close contract
Hi @Silviu8
Welcome to the EE Community
If you wish to cancel your contract you need to contact the retentions team to give 30 days notice ring 150 and select the option to leave EE.
Thanks,
David.
by Ace Contributor
Solution
Re: Close contract
Hi @Silviu8
Thanks,
David.
