by Spaniel-1968
Changed my phone now can't send or receive picture messages
 I've just changed my phone from an iPhone 4G to a Samsung Jet now I can't send or receive picture messages posted help
EE Employee
Solution
Re: Changed my phone now can't send or receive picture messages
Good Evening @Spaniel-1968
Just to add to @Profile closed's reply - you can also use the EE Setup pages and click on Photo messaging.
This will send the settings to your device.
Have a nice evening!
Thanks - Karen. Smiley Happy
by Profile closed
Not applicable
Hello @Spaniel-1968 sorry to hear you are having trouble sending/receiving MMS. Try sending them with WiFi turned off as sometimes this can block your connection. You do not need an active data allowance to send and receive but you may need mobile data active. Here is a link containing the EE MMS/APN settings if you would like to check they are correctly set/stored on your phone. :):
https://community.ee.co.uk/t5/4G-and-mobile-data/EE-APN-settings-Where-to-find-them/td-p/132083
EE Employee
Solution
