by JustJason007 Investigator
Casting
My new phone experia za 2 has casting problems. Keeps loosing volume and then disconnects
8 REPLIES 8
by Ace Contributor
Re: Casting
@JustJason007 I’m really sorry to hear this.  I think it’s best to contact customer services on 150 and somebody will be able to assist you. Please let us know how you get on .
Re: Casting
Hi @JustJason007
What device are you using to cast (Apple TV, Chromecast etc).
What are you casting (YouTube etc)
Re: Casting
Hi
I am using Chromecast. , Google home. It works on my old experia phone
and my old HTC phone.
Re: Casting
Hi there @JustJason007
Is your Google Play Service up to date?
Speak soon, Leanne 🙂
Re: Casting
It's Google home that casts images on the tv .
Re: Casting
Hi @JustJason007
Has this worked on your new phone previously?
Re: Casting
Hi @JustJason007
That is your problem here not your device. The latest update us causing people various issues.
Try using a third party casting app from the play store to see if that has the same issues.
Re: Casting
Thanks for your help
Can you recommend a casting app
