by cassgreensmith1 Established Contributor
Car mount
Looking for a decent phone holder for my note 8 in the car. I love the minimalist look of the magnetic ones but hav heard it can affect wireless charging, NFC, android pay all of which I use. Not really a fan of vent ones as my car has vertical vent bars and don't think a heavy phone like the note 8 will be kept stable with them. Any suggestions? Anyone using a magnetic and getting wireless charging and android pay?
Solution
Re: Car mount
You could try one of these:
https://www.amazon.co.uk/Holder-Universal-Mobile-Cradles-Dashboard/dp/B073J26K2H/ref=sr_1_23?ie=UTF8...
Or
https://www.amazon.co.uk/EReach-Silicone-Non-Slip-Samsung-Different/dp/B01DWEXM82/ref=sr_1_16?ie=UTF...
Or
https://www.amazon.co.uk/Skybaba-NonSlip-Dashboard-Universal-Smartphone/dp/B073TRKWWW/ref=sr_1_22?ie...
Making something yourself is a risk if it fails.
If you do get one of the above please let us know how it goes.
Thanks,
Re: Car mount
Do you have a CD player? Try this one as its the one I use for my G6
https://www.amazon.co.uk/Mpow-Universal-Rotation-Samsung-Motorola/dp/B019DCBJYQ/ref=sr_1_1?ie=UTF8&q...
I have tried loads of different ones out but this one is the one that I like the most.
I don't like the magnetic ones (with a sticky disk) as like you say you need to attach something to your phone.
Thanks,
Re: Car mount
That looks great but unfortunately my cd slot is very close the floor and I wouldn't be able to see it 🙈. I'm thinking of getting kenu airframe+ and modifying it to stick it the dash somehow.
thanks
Solution
Re: Car mount
Or
Or
Thanks,
EE Employee
Re: Car mount
Hi @cassgreensmith1 and welcome to the community.
Let us know which one you go for 🙂
Cheers
Lee
