by Toffer68
Cant use phone abroad
Hi any help i cannot use my phone abroad
EE Employee
Re: Cant use phone abroad
Hi @Toffer68 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
