by Skindo
Cannot turn off call forwarding
I have previously set my Huawei P9 to forward to another device.
I thought I had turned this off, and the phone says it's disabled, but calls still forward to my other device.
I have tried putting my sim in anorher device but it still says it's disabled but the calls are forwarded.
by Skindo
Solution
Re: Cannot turn off call forwarding
Thanks for the reply Winston.
I spoke with EE tech support and they sorted the issue for me .
I'll certainly keep those codes for future reference if I encounter the problem again.
Many thanks.
by Ace Contributor
Maybe give the following GSM code a try?
- Disable unconditional forwarding
##21#
Please make sure that you call the above command in 2G or 3G mode.
You can also check the status of the forwarding by calling *#21#
W
Hi @Skindo
Welcome to the community. 🙂
Did @winston's advice help cancel the divert?
If you're still having problems, it may be worth speaking to our Tech Gurus.
by Skindo
Solution
Many thanks.
