by Mlf Investigator
Cannot text from abroad despite roaming
Hello. I'm in Denmark with my Galaxy 5 (2017). I can make phone calls but cannot send texts.
I'm on a contract.
I hope you'r able to help.
Cheers, Mike
Re: Cannot text from abroad despite roaming
Is your text message centre number +447958879879
If you have roaming active then it should work. Try restarting your phone a couple of times or manually connecting to another network.
by Mlf Investigator
Hello. Many thanks for the message. I cannot see anything wrong - the message centre number is correct.  The network... It's set to connect automatically but I have also tried manually (only one network available). I've restarted a couple of times. Still won't send texts.
EE Employee
Hi and welcome to the community @Mlf
Please can I get you to manually type one of you contacts into the recipents box manually +447 etc and then complete a message.
Does this helps?
Many thanks,
Lee
by Mlf Investigator
Many thanks Lee. Still no joy though. For all it's worth, when we landed in Copenhagen my wife got the text message saying welcome abroad, you're roaming etc. I didn't get any message. So is it something about the network?
EE Employee
Hi @Mlf
It is very strange as you are able to call, please do give customer services a quick call as they will be able to see if anything needs tweeked at our end.
Many thanks,
Lee
