by IGS
New Member
Cannot access wifi in Italy. Tried restart. Solution ?
Cannot access wifi in Italy with message unable to obtain IP address. Tried restart and switching off mobile data but still no success. Samsung S8 Any solution suggestions please ??
Re: Cannot access wifi in Italy. Tried restart. Solution ?
@IGS   WiFi or a cellular data connection?  WiFi has nothing todo with EE this is between your device and the router your trying to connect to.
