Highlighted
New Member
Can the memorary of the S10e be expanded using a sd card
Can the memory of the S10e be expanded
Highlighted
Re: Can the memorary of the S10e be expanded using a sd card
Good Afternoon @Titters.
Yes, you can use an SD card to expand the memory on your S10.
Katie 🙂
