by TheBigCrock Investigator
Can't get wifi chat options on android messenger
I have installed android messenger but can't get the wifi chat options such as see when someone is typing or see when message is read, is anyone getting the same problem. I have read somewhere that carrier doesn't support this.
Re: Can't get wifi chat options on android messenger
Hi @TheBigCrock
EE network doesn't currently support RCS, Its not currently supported on EE. There are other issues also in that this app isn't secure/encrypted and that features need to be supported by both network carrier not just one.
Thanks,
Hi @Northerner
Thanks for the answer, hope EE change this.
