by Tricky15
Can't get 4g on my cubot x18 plus
Why can I not get a 4g signal on my cubot x18 plus phone
Solution
Re: Can't get 4g on my cubot x18 plus
@Tricky15  Is the sim in the right sim slot ?  as most 2 SIM card devices only support 4G in one slot not both.
Solution
by Tricky15
Chris b tried in both slots. Been to ee shop today. Said phone is unsaported. But in that case I wouldn't be able to get 3g either. ???. Put a Giffgaff simcard in and it works perfectly on 4g. And I know 4 people with this phone all on different networks and ee is the only one that can't pick up 4g
@Tricky15  The networks use different bandwidth to get a signal to their customers.  What works on one network doesn’t mean it will work on all networks.
Hello there @Tricky15
Thanks for posting on the community.
Have you been able to try the SIM in another phone to see if 4G works?
Thanks, Leanne.
