by Gingerjon69
Can i use my sim card and data in a ee mini wifi box
by Gingerjon69
Can i use my phone sim in a mini wifi box
How many more times do i have to type out the same question EE?.
Can i use my phone sim card and data in a ee mini wifi router?
Re: Can i use my phone sim in a mini wifi box
Hi @Gingerjon69
There is no need to be rude. If you wanted a quick answer then you should have called CS on 150.
The answer to your question is yes.
Hello @Gingerjon69
Thanks for coming here 🙂
If the SIM card is the same size, you can use this in any EE or an unlocked device.
Thanks.
