by Maple12
New Member
Can I use my plan, data in Canada, thanks
Re: Can I use my plan, data in Canada, thanks
Hi @Maple12.
Thanks for coming to the community 🙂
If you're on a Max Plan, post-10 May 2017, or you have the Go Further Swappable on your account, then you'll be able to use your plan in Canada as normal.
Have a look at our Roaming Page online for more information.
Jon
