by Diane54
New Member
Can I use my phone in Tunisia
Can I use my phone in tunisia
Solution
Re: Can I use my phone in Tunisia
Hi @Diane54
Yes you can but it will cost you as Tunisia isn't in the EU. These costs can be found here together with any add-ons.
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/tunisi...
You should also text ROAMING to 150 to ensure your service is activated.
Solution
Hi @Diane54
