by vivmick
New Member
Can I upgrade my husbands phone
Re: Can I upgrade my husbands phone
Hi @vivmick
If you text UP to 150 on the device, it will tell you if you can upgrade.
Hi @vivmick
Welcome to the community. 🙂
If your husband's phone is on the same EE account as yours, you'll be able to check through your My EE account too.
