by JJBN Investigator
Can I swap my EE SIM card from s8 into s10plus ?
I have a S8 and want to buy a S10 plus before my plan finishes, so can I swap my EE sim into new phone until my contract finishes, and when I install it into new phone will I be tied to that network when it comes to renewing my plan ?
Solution
Re: Can I swap my EE SIM card from s8 into s10plus ?
Hi @JJBN
Both use a nano SIM so you can just swap them over. You can use any phone with your SIM, you aren't restricted to your device.
That's a great upgrade btw, enjoy 👍🏼
Solution
Hi @JJBN
