by Owen241111 Investigator
Can I block from buying on play store
I'm just wondering if u can block or put a security on Google play store as my autistic child keeps buying games and it's adding onto the bill???
EE Employee
Re: Can I block from buying on play store
Hi @Owen241111 and welcome to the community.
If you head over to https://payments.google.com/payments/home#paymentMethods, you can remove the subscriber billing options.
hope that helps,
Lee
